steering wheel play in 40 dc
wilson
03-14-2007 18:21:31
How can I adjust steering wheel play ( 1/4 turn) on 1940 dc as there are no shims and later shims do not fit. shaft has no lower bearing. I did adjust set screw on shaft with arm to front but this play is between the wheel worn gear and the gear connected to the drag link arm.This is the steering shaft with throttle on steering coloum.
Tom Railsback
03-14-2007 19:18:22
 Re: steering wheel play in 40 dc in reply to wilson, 03-14-2007 18:21:31
Bill:
The service manual says to take the steering arm off and rotate the shaft 1/3 revolution so there are new working surfaces between the steering worm and steering worm wheel.
Tom
