dc
johndeereman
03-14-2007 06:13:17
going to redo my dc in a couple of weeks was wondering how you guys true the top of the block without taking it to a machine shop in school we used something that looked like a old hand plane with emery cloth on it but i cant remember what they called it or where to buy one. also thinking about the future what combine engine will bolt into my dc ive been told that the combines had a smaller bore but a longer stroke is this true? thanks johndeereman
Nedd
03-14-2007 09:05:33
 Re: dc in reply to johndeereman, 03-14-2007 06:13:17
I think it is the SP-12 model combine that has the DE motor in. SP-9 has an SC motor in.
wilson
03-14-2007 08:54:18
Millwrights call it STONNING as a large stone like you might sharpen a knife is used to true up a head or block I have used a new flat file careful to not upt enough pressure on the blade as to bow it but gently rubbinh the length of the block or head a true (not off the rack but machined) piece of flat metel shpuld be used to determing how much to remove with feeler guages under the flat stock. A DE combine motor will work fine the de usually has 4 inch alum pistons and is rated at 1450 rpm (200 faster than the tractor) however any d series with alum pistons can be run this fast or faster as the limiting factor is the amount of weight of the piston. I am told some combine engines had a slightly different govenor however a de I am presentky putting in a dc seems to have the same govenor weights as the tractor
Gary in Pulaski
03-14-2007 13:36:22
 Re: dc in reply to wilson, 03-14-2007 08:54:18
My late father bought a Case 120 self propelled combine in 1955.(the year after I was born) we did a lot of custom work for neighbors in the 60s. The combine stood in the shed for about 18 years. The motor was seized VERY tight. Everyday for three weeks, I sprayed "PB Blaster" in the sparkplug holes, and it finally came free. I can tell you that it only ran for about 1.5 minuets,before it stopped tight. But started easily again in about 1/2 hour.A lot more to say, but space limited. (I put 2cycle oil in the gas!!) It runs great!! I have used it several times since. Someday, maybe I'll post a picture. The motor is a "DE". I own 3 dc's too, and want to rebuild them someday.2 hand clutch. one DC4, and one w/ Eagle Hitch. I Need fenders, lights, battery holder/cover and steering arm.etc. One "SC" according to mu dad, the first rubber tired tractor in Shawano county! This has a cultivator, two bottom steel wheeled plow, quack digger,and is still in the same family.Also needs fenders, lights, and major motor overhaul. Pistons rusted tight. I took the head off and cannot budge any pistons. Probable work from the bottom up--.
