Case LA head
scott6143
03-13-2007 18:48:04
I"m putting new gaskets in my "49 LA and while checking things out noticed it has a 6.5" stroke instead of the 6". I have not checked the bore yet. Is there a way to find out if I have the gas or LP head, part number differance or something? I"m thinking if somebody had it stroked they may have put an LP head on it, as it is the engine has a hard time turning over with a new 12v battery. Thanks in advance for your help, scott6143
Thad
03-14-2007 16:54:45
 Re: Case LA head in reply to scott6143, 03-13-2007 18:48:04
The casting #s for the high compression heads are 5845 for the high comp gas head and the lp is 6386. Both have a bathtub shaped chamber one is alot shallower than the other for more compression. Thad
Walt Davies
03-13-2007 23:30:57
LP head has a small oval shaped chamber where the others are round and as big as the bore. Walt
