VAC Torque tube
BigBilly
03-13-2007 15:05:00
What is the story behind oil in the torque tube. what is it for, what kind of oil is it, where does it go in at?
Thanks
Joe (Wa)
03-14-2007 15:21:45
 Re: VAC Torque tube in reply to BigBilly, 03-13-2007 15:05:00
I didn't address all your questions in my response.
The fill is a 3/4" pipe plug located on the left side of the torque tube just forward of the clutch pedal. Full is to the lip of the plug opening. Capacity is 8 qts.
For later VAC with live hyd pump, recommended fill was motor oil SAE 5, SAE 10, or SAE 20 pending ambient temp. Many people now use 10-30 motor oil or a general purpose hyd oil. The 4 bolt flange below the fill plug is access for the return oil filter element. Element is edge wound, cleanable type.
Older tractors w/o live hyd pump used the same 90 wt gear oil in the torque tube as the transmission.
Joe
Joe (Wa)
03-13-2007 18:11:31
On VA series tractors (generally 1949 & later) that had the engine mounted live hydraulic pump, the torque tube was used for the reservoir.
Other VA series tractors, with or without the hydraulic pump driven by the belt pulley gearing, had 90 wt oil in the torque tube as a lubricant for the drive shaft bearings and belt pulley gears.
Joe
