vai motor stuck
tim coltman
03-09-2007 20:49:27
hi i am starting work on my vai got the motor out. now im planning on rebuilding after tearing it apart and seeing what it needs but the pistons are stuck this is my first time dealing with this. any suggestions in dealing with this. havent done anything with it other than pull the plugs and spray pb blaster in. thinking about pulling off the head tommorow night and taking a look. then what????? ?? not sure how to deal with this yet. thanks tim coltman
C. Amick
03-12-2007 09:56:12
 Re: vai motor stuck in reply to tim coltman, 03-09-2007 20:49:27
I would fill the whole engine up with a penetrating oil solution and let it set for a while before you start trying to get it unstuck. The valves are probably stuck as well. There are some good articles in the article archives on this web site on freeing stuck engines. One guy mixes one part automatic transmission fluid, on part kerosene, and one part Marvel Mystery Oil. If you try to turn the engine over without the head on it, you may end up popping the sleeves loose and the pistons will still be stuck.
watsonsgotit
03-10-2007 05:04:45
Tim, If you are planning on totally rebuilding the engine, you might as well remove the head and pan, remove the rod caps, and get you a piece of wood and a sledge hammer. They will come out, but they will probably be tight.
