Yuma tractor
Ken in AZ
03-09-2007 16:05:31
Got my treasure hauled back from Yuma earlier this week but had to get back to work.
Serial tag says model 400, number 8062800
It"s a wide front diesel with an eagle hitch. Can someone pin a year on the number?
I need to get a set of manuals, filters and probably a couple tires. This one has what looks like a rice tire on the back but it"s pretty sun-rotted and doesn"t want to hold air. The others I think I can still use.
this rig has a one-wire alternator on it now so I assume it"s set up 12 negative ground.
It also has some sort of hand pump assembly next to the gages. Looks like maybe a liquid ether pump because it goes into the manifold. Is this an aftermarket setup or was this a factory option? And do these need help starting? It"s my first Case diesel.
Thanks!
Ken in AZ
bradley martin
03-10-2007 02:15:04
 Re: Yuma tractor in reply to Ken in AZ, 03-09-2007 16:05:31
The vacum gauge will indicate restricted fuel filters, particularly the final filter.
Tom Railsback
03-09-2007 18:51:20
Ken:
My data shows that your 400 was built in 1955.
Tom
iluvcase
03-09-2007 17:03:36
Your tractor is an early 1955 model. The ether canister on the left side of the dash is original equipment on these old girls. It was used by putting an ether pellet into the canister and pushing down the plunger to break the pellet and the ether would get sucked into the intake manifold to help start it in cold weather. If you are going to use it in cold weather a tank heater works very well. Use ether sparingly...use only enough to get the job done. It can cause severe engine damage if you do'nt know how to use it. If she's set up right she should only need a little squirt into the air cleaner and she will run. It's better if you do'nt have to use it.
Ken in AZ
03-09-2007 18:39:37
 Re: Yuma tractor in reply to iluvcase, 03-09-2007 17:03:36
Thanks for the information. I wasn't sure if the ether system was stock; it is well done but I haven't heard good reports on ether being good for these tractors. Since it's in AZ, it shouldn't be too much trouble to keep it warm instead of ether-starting them. (been there, done that in Montana on M-M 705's @ -20 and worse)
So what does the vacuum gage show? Is this to indicate a plugged air filter or something?
thanks again!
Ken in AZ
Doc Larry
03-10-2007 18:56:23
 Re: Yuma tractor in reply to Ken in AZ, 03-09-2007 18:39:37
Ken,
I"ve got 401 #8062179 wide front diesel Eagle hitch very similar if not identical to yours - if you have questions I"ll try to help. Mine starts without ether down to about 35 above or so.
I"ve got an extra owner"s manual missing the outer cover but otherwise complete that"s for sale - search the classified (see left column near top) for 400 under state MT and you"ll see it.
Larry
Ken in AZ
03-11-2007 20:04:40
 Re: Yuma tractor in reply to Doc Larry, 03-10-2007 18:56:23
Thanks Larry. I might have to take you up on that.
Ken in AZ
