Rear Axle Seals
Kestrel CT
03-07-2007 15:08:04
third party image
Anyone know which side of replacement rear axle seals slides in first on the axle of a Case VAI ?
They are new Case seals, are somewhat thinner than the original and the rubber seal extends only half way across the inside body of its' metal shell.
The photo shows it dangling on the axle with the rubber side "out". Its difficult to explain but it must make a difference. Any help appreciated. I can post another photo angle if needed. Thanks..... .
bradley martin
03-09-2007 07:33:21
 Re: Rear Axle Seals in reply to Kestrel CT, 03-07-2007 15:08:04
If your axle is badley grooved you would need to install a "speedy sleeve"before installing the seal. They are not cheap but they work great and are far cheaper than having a machine shop buiuld up the worn arears and then turn them down. Good luck.
bradley martin
03-07-2007 15:57:44
The rubber lip(i.e. the open or unattached side of the rubbler goes toward the tractor, If installed backwards it will not hold. The other way to tell is the side the seal number is printed on should be to the outside. Good luck.
kestrel CT
03-07-2007 16:55:39
 Re: Rear Axle Seals in reply to bradley martin, 03-07-2007 15:57:44
Thanks Bradley for the quick reply. They slid on fairly easy but firmly. I just put the axle housing with new gasket back on the tranny; she's starting to almost look like a tractor again.
Mathias NY
03-09-2007 04:33:51
 Re: Rear Axle Seals in reply to kestrel CT, 03-07-2007 16:55:39
Make sure you lube the seal likes with a film of oil before you slide them on the axle. A dry seal will wear out prematurely and probably grove the axle in the process.
Kestrel CT
03-09-2007 04:45:29
 Re: Rear Axle Seals in reply to Mathias NY, 03-09-2007 04:33:51
Thanks for the tip. I was just going to install them today and could use a little guidance on the proper way to tap them ino the housing.
Is the axle normally slid in first and then the seal tapped in ? I don't have a pipe big enough and was just going to lightly work it in with light taps with a piece of wood until seated. Maybe grease it a little first ?
I should have asked this before but I have several projects going on at once.
Thank you again...
Joe (Wa)
03-09-2007 10:25:31
 Re: Rear Axle Seals in reply to Kestrel CT, 03-09-2007 04:45:29
ABS or PVC will work in lieu of pipe. A piece of board with axle size hole between the driver and seal will spread the impact and protect the seal face but isn't necessary if you're careful.
Joe
Mathias NY
03-09-2007 06:46:34
Make sure the axle is free of nicks and burrs before sliding the seal over it. Make sure it has some lubrication on it.
A block of wood will probably work. Be carefull not to let any wood chips get behind or under the sealing lip. The important thing is to keep it square as you tap it into the housing. If it cocks on you it may be difficult to square up.
If there is a groove in the axle from the old shaft, you should make sure the new seal does not rest on it.
Good luck.
