Case 210B push rod dilemma --
Jas
03-06-2007 19:15:34
This past fall I took the head off my 210B and brought it to a machine shop and covered the engine up and oiled the cylinders and left the push rods in the same spot that they were already in. Well about 3 weeks ago I went out there to put it back together so I can start it so I can put it on my trailer so I can move it to a different location, well one pushrod is missing. So I now need this and can't find any locals that have any or even know where i can get one. So this is my dilemma .... any suggestions or parts help would be great. Thanks J
VAC Lee
03-07-2007 07:40:15
 Re: Case 210B push rod dilemma -- in reply to Jas, 03-06-2007 19:15:34
I think if you compare the VAC push rod with 200 push rod you will find that the 200 is shorter. I don't think that they will work because the rocker will bind on the valve. The head is not as tall on the 200 as the VAC or 300. You can have a VAC rod cut at a machine shop. Might be easier that finding a 200 rod. There is approximately .250" difference.
1031D
03-07-2007 07:22:45
you can use a pushrod from a VAC, 200, 300, 400, 430 as long as it is gas.
TimBinWV
03-07-2007 04:58:14
Hey,Jas..I have some out of a VAC that I bought from ebay just to get one. I'm not sure if they're the same,but you can have one if you need it.The VAC is a 124 cu.inch motor,I don't know what the 210 has in it.
Jas
03-07-2007 09:28:37
 Re: Case 210B push rod dilemma -- in reply to TimBinWV, 03-07-2007 04:58:14
Hello, Thanks for the offer, I found the part number from another tractor helper and I just bought one. I hope it works but if it does not I will contact you and take you up on your offer. Thanks a bunch. Now I think I am going to start looking for a parts list for the tractor and engine. I already have one for the backhoe part and the loader part. I could also use a repair manual. Thanks Again, Jas
BarryfromIA
03-07-2007 05:15:45
Rumor is, that the 200's engine was the same as a vac, it was just in a newer chassis.
