magneto
Gary Mantei
03-06-2007 13:18:28
I have a 1936 Case C and need spec's for the Bosch magneto, model #MJA4B - 112 Besides points setting info. is there anything special about adjustments because of the manual spark advance etc. I have not removed the points but they look good at a glance. There currently seems to be no spark, although the wires are very old. Is there a particular Case book that I should get for working on this model? If so, where do I get it? I am thinking I will have to do a major rebuild of the manifolds or replace them. I'm all ears for info and suggestions.
M5G
03-07-2007 11:02:09
 Re: magneto in reply to Gary Mantei, 03-06-2007 13:18:28
Case C lists a Case Make Mag 4jMA; however, a Bosch MJA-4Bll2 is listed for a Model L. Nevertheless, the mag breaker gap is the same at .015. Listed for a Model C: Magneto impulse trip point is TC, Magneto Lag Angle Degrees is 25, Flywheel Mark Indicating: Magneto Impulse Trip Point = D. Hope this helps!
