eagle hitch
mike in troy
03-05-2007 05:42:35
Will any three point equipment work with the Eagle Hitch? Thanks,Mike.
Paul f
03-06-2007 04:58:04
 Re: eagle hitch in reply to mike in troy, 03-05-2007 05:42:35
I use a Farm King 7ft back blade, a New Holland finish mower and my neighbors Brush hog and York rake on MY DC3 and VAC eagle hitches. As indicated the DC PTO is high and the shaft runs at a pretty steep angle. I keep them well greased. One problem is lift on the DC3. When PTO is used you have to mount the top link to the Eye on top of the PTO unit. The geometry means you may not be able to lift the implement as far as you would like. (One solution is to raise the mast on the implement that the top link attaches to) For a non PTO driven attachment you use the PTO cover as the top link mount point and the geometry is correct
Roger300
03-05-2007 14:19:11
If the spacing on the emplement is close, but the arms have play in them and slip off the pins
you can compensate for that by putting washer on the pins with a spring clip in the holes. The Case implements have pins with a stop on both sides to prevent the play from causing it to detach. Take care, Roger
mike in troy
03-05-2007 13:01:07
Thanks for the help. Has anyone had any luck with a 2 bottom Dearborn/Ford plow behind a VAC with the Eagle Hitch?
GEOMO
03-06-2007 05:52:36
 Re: eagle hitch in reply to mike in troy, 03-05-2007 13:01:07
I PLOWED WITH A DEARBORN AND A CASE PLOW IN THE LATE 50/EARLY 60.
I DO NOT REMEMBER ANY DIFFERENCE AS FAR AS GETTING IT DONE.
PhilcaseinWPa
03-05-2007 11:44:36
Some but not all cat 1 3ph will fit. If the EH is good and tight there is no side movement but some older units with wear where the arms attach to the tractor may move 3 or 4 ". A bigger problem than the hitch are pto shafts. The EH arms are shorter than most standard 3ph so pto shafts often have to be shortened. Also the pto drive is somewhat high on the Cases w/ EH so often the pto is forced to run at a sharp angle which can be hard on the universal joints of the pto shaft. btdt.
Phil
C. Amick
03-05-2007 09:17:35
If the implement pins are too far apart you may have problems. The Eagle Hitch arms don't have much movement side to side. You need a width of approximately 28 inches. I have turned one of the implement pins around to the inside to make things work.
BarryfromIA
03-05-2007 07:38:48
Eagle Hitch is a cat 1 hitch. Some pieces have less clearance around the pin area to clear the castings that make up the hitch part of the arm end. Sometimes a short piece of 3/8" strap can move the pin forward enough to make it work. Once you get it set up you can hook up without getting off, mostly.
BarryfromIA
03-05-2007 12:05:41
 Re: eagle hitch in reply to BarryfromIA, 03-05-2007 07:38:48
My 8' rear blade is a cat 2 hookup had the pins moved forward with several pieces of iron and the cat 2 pins turned to the inside. It has was used this way since about 1969. The arms on my 311b have some wear in the mounting points.
