VAC hydrolics
Mike in Troy
03-04-2007 15:24:16
Any one know why the hyd. fluid foams out of the vent on a VAC? Must be getting air from some where but I can't figure where. Thanks.
mike in troy
03-04-2007 22:33:40
 Re: VAC hydrolics in reply to Mike in Troy, 03-04-2007 15:24:16
Thanks guys. Already replaced the piston seal. Must be the cylinder housing. Mike.
Joe (Wa)
03-05-2007 00:04:11
 Re: VAC hydrolics in reply to mike in troy, 03-04-2007 22:33:40
Mike, The cylinder isn't likely worn, it would just about have to have visible scoring to leak with new seals. If a cup, it can be installed off center. Cup screws are tightened with the piston upside down in the cylinder to ensure centering.
Take the leakbye/vent tube off at the rock shaft housing and work the hitch through about 10 cycles, check how much is leaking through.
Sump is not overfull? Full is at the lip of the plug opening.
If you can live with some draft arm leakdown, raise the vent 6" or higher with a pipe nipple and union.
Joe
Joe (Wa)
03-04-2007 18:32:01
Yeah, it is likely piston leakbye. What happens is that some of the leakbye oil puddles in the rockshaft housing grease. When the hitch is raised, the piston is going down displacing air, grease & oil out of the rockshaft housing forcefully through the leakoff/vent tubing back into the torque tube.
The piston can either be the leather cup type or the two o-ring type. The cylinder will accept either piston but the piston is dedicated to either a cup on top or o-ring lands on the side. The change from cup to o-ring piston occurred during the '51 model year but it is best to eyeball the piston before buying parts regardless of the model year.
Leather cup is p/n V22900, cross-ref p/n A30798.
O-ring (2 reqd) is p/n V20353, cross-ref p/n A30757.
Joe
Rugertime
03-04-2007 16:12:58
When mine did that it was due to a failed cup on the ram in the hydraulic cylinder. Fuild was getting past the ram in blowing out the vent.
Case now mades a replacement cup made of man made materal, not leather like the orginal.
