Case plow colors
Scott KY
03-03-2007 18:20:31
I know this has been discussed before but I am restoring an eagle hitch plow and I want to get the colors right. From what I have learned the frame is Flambeau red, the A frame hitch, the furrow wheel and the coulter yokes and shanks are green. Should the clamps that hold the coulter shanks be flambeau or green? What about the backs of the moldboards? Black? And the moldboard brace? Any help would be appreciated.
charley hellickson
03-09-2007 20:29:23
 Re: Case plow colors in reply to Scott KY, 03-03-2007 18:20:31
Scott KY. Sorry I told you wrong on your plow colors. I saw on EBay two Case sales books for the SC and DC tractors with eagle hitch, the plow was mounted on and plowing. The pictures were in color. The whole plow was flambeau, everything. Plow was same color as the tractor. Back of moldboards was flambeau. Hope this helps. Good luck. Charley.
Camboted
03-04-2007 05:16:53
It was the "Century" series from the late 40's and early 50's that were tri colored (pull type)
Mark in Iowa
03-04-2007 08:09:27
 Re: Case plow colors in reply to Camboted, 03-04-2007 05:16:53
I just put a couple of pictures in the - Implement Photos - of a Centennial pull type plow.. I would put them here put haven't been ably to figue out how yet... Mark
Charley Hellickson
03-03-2007 22:09:32
Hi Scott. Is this plow the one you said erlier that you had a 3 bottom BER with the turnbuckel? If so there is no flambeau on it. The BER and BE plows are all green. I know a guy who had a 51 VAC with a eagle hitch plow that his Dad had sold new when they were a dealer and a few years later they bought it back. That plow was all green. I have a BE 314 plow that had real good paint when I bought it, all green. The model M plows that came out in 58 were all flambeau. Hope this helps. Charley.
JGarner
03-04-2007 12:25:01
 Re: Case plow colors in reply to Charley Hellickson, 03-03-2007 22:09:32
As I recall on our BER (purchased new in 1954) the break away mechanism and tail wheel was Flambeau and the remainder was the Case implement green. I believe the A frame for the top link hitch point was green too.
L.Lamp
03-04-2007 08:14:32
I have a 2-14 mounted Case plow that I bought on a farm sale in 1972 for $20.00. It is all a darker green, everything. I don't know what model it is but the hitch attachment breaks away from the plow if you hit something. It looks like a big bale spear when released from the main part of the plow.
Scott KY
03-04-2007 07:47:03
It is a BER. I have an owners manual for it and in the pictures(which are black and white) there appears to be two shades like there are two colors. The spring 2006 issue of Old Abe's News has an eagle hitch plow on the cover painted flambeau and green which looks good. Anyway if the plow is solid green would the back of the moldboards be black or green?
charley hellickson
03-04-2007 20:01:35
 Re: Case plow colors in reply to Scott KY, 03-04-2007 07:47:03
Hi Scott. I learned something from this. On my BE plow the back of the moldboards are green, same as the rest of plow. On my CH pull plow the backs are flambeau, that is when they started painting the whole plow flambeau with deseart sunset wheels. A good bet would be moldboard backs same color as frame. Good luck. Thanks. Charley.
CKRICHARD
03-04-2007 14:46:23
Scott you are right the top that brakes away is flamdeau and the bottom is green not sure about the moldboards the older vac EH plow is all green
