DI rod and piston
Casi DI
03-03-2007 09:08:44
Anyone out there know where i can find a connecting rod and piston for a DI? Is it the same as one for a D? I can get it to run on three cylinders, but that doesn't do me much good. Thanks.
DCDENNIS
03-03-2007 17:44:54
 Re: DI rod and piston in reply to Casi DI, 03-03-2007 09:08:44
I GOT MY 31 TOOTH SPROCKETS OUT OF A DO, AM HAPPY WITH THE RESULTS, BUT IT IS A LOT OF WORK CHANGING. DCDENNIS
wilson
03-03-2007 14:04:39
I am sure I would have one but what size is yous 3 7/8 cast 4 inch alum 4 i/16 m&w??? I would like to find a set of 26 or 31 tooth d series rear sprockets. would you have any extras??
joecool
03-03-2007 17:21:35
 Re: DI rod and piston in reply to wilson, 03-03-2007 14:04:39
what model would these sprockets be in? we have a d, dc-4, several dc's and a set we took out of a c that was to fast for us in farmstock pulling. let me know which model to look into
WILSON
03-03-2007 20:03:03
 Re: DI rod and piston in reply to joecool, 03-03-2007 17:21:35
I could use either d serise 31 tooth which would be in a standard D or 26 tooth which are in DI's. Also I could use 31 tooth from a C or 26 fron a CI. I plan on changing the rear axels and have both c and d axels so either splined or bolt on would work, I have extra 31 tooth cc style and dc (bolt on ) to sell or trade. its easy to check which you have by feeling through the fill plug on right side rear just above the drawbar
watsonsgotit
03-03-2007 16:29:14
Wilson, I have seen your post wanting the rear sprockets before. I don't know what models you would find them on, but if it could be a DI, there are two in James Storey's salvage yard in Tennessee. He can be reached at 1-800-241-5670.
watsonsgotit
03-03-2007 16:28:51
Case DI
03-03-2007 17:24:26
 Re: DI rod and piston in reply to watsonsgotit, 03-03-2007 16:28:51
I'll get back with that info.
