transmission hydralic fluid filling,,where???Help!
Karen Ann
03-02-2007 13:45:14
Hello, I bought an older 1959 Case 210B tractor
last year,I had a gentleman ranch hand,
who helped me get her all running, to work
the ranch, I pulled the oil stick out, and it
was "low" now I believe I fill that up top,
on the engine, and I know what oil, BUT, I thought the whole transmission/hydrolic
engine, all ran on one big resivoiur of oil,
told to me, ?? Where do I check my transmission
fluide level, and where do I fill this? thank you so for helping me, really appriciated!!
Karen Ann
03-24-2007 22:26:03
 Re: transmission hydralic fluid filling,,where???H in reply to Karen Ann, 03-02-2007 13:45:14
Barry, you sort of lost me, on the info about the
shifter head cover, and shuttle? I did find the hex bolt shaped thing under seat,
and checked that, it had very brown, foamy (what
little bit showed on stick) type oil. Isen't
this also the same place I would pour the
hydralic, or gear oil? and when i go to buy it,
would I be looking for "gear oil" or is it
type F transmission fluid? My tractor seems to
be very very slow, to move, when it is put into
1st gear, it takes a lot of gas, reving to get
it to go foward, is this due to lack of this oil,
or clutch oil? ( I am a women, not really a mechanic, and trying to keep this well needed
and used tractor running correctly)
BarryfromIA
03-02-2007 14:49:01
Excellent small tractor you have there. The rear gears and the 4 speed tranny have fill plug directly below the seat with a dip stick attached to it. All that I have seen are a large hex head that is threaded in. If you have 3point the rear is likely to be over filled. There is a cover that holds the shifter for high or low and the shuttle shift ahead of the 4speed shifter cover, anyway there is a small square head pipe plug with a stick to gauge the oil level and a larger pipe plug for filling. Use good hydraulic oil. The rear end should have 90wt. Clean very well around these plugs before opening.
