differnces between 511-b and 611-b
jaker3
03-02-2007 09:20:47
What are the main differences between a 511-b and a 611-b?
charley hellickson
03-02-2007 23:14:45
 Re: differnces between 511-b and 611-b in reply to jaker3, 03-02-2007 09:20:47
Hi. 511B and 611B are the same exact tractor except for tranny. 511B is the standard tranny with dry clutch, option was triple range and hand clutch for PTO. 611B is case-o-matic with dual range for a total of 16 gears, also independent PTO with PTO clutch lever on right side above floor board. 511B did not have independent PTO. Engine 164 cu. in. 36" rear wheels. Case used the two number model system to tell which tranny it had. Even no. C-O-M, odd no. standard. Hope this helps. Charley.
djm75
03-03-2007 04:14:42
 Re: differnces between 511-b and 611-b in reply to charley hellickson, 03-02-2007 23:14:45
If even # are COM they why does the 400 and 430,830 have standard trans? I"m confused
charley hellickson
03-03-2007 21:26:01
 Re: differnces between 511-b and 611-b in reply to djm75, 03-03-2007 04:14:42
Hi djm75. Case only used that tranny numbering system for two years,58-59. C-O-M came out in 58. On the thirty series tractors you could get either tranny. If it had C-O-M then they put a letter C after the model number on the serial plate, like 731CXXXXX . I learned this a long time ago, late 70's, after i bought a 311. I got to know a Case salesman, Dave Witte, if memory and spelling is right, up at the Boone IA, Case store. I learnrd somethings from Dave. Hope this helps. Charley.
Slip-o-matic
03-03-2007 13:07:13
300, 350 and 400 never had c-o-m.
200B, 300B, 500B and 700B never had c-o-m.
400B, 600B and 800B only had c-o-m.
430, never had it.
530, 630, 730, 830 c-o-m was optional.
900, 900B, 930 and 930CK never had it.
wheat straw
03-02-2007 19:57:55
I don't remember exactly, but I think this is how it was.The 500 and the 600 in the b series had the same tranny options, COM or triple range. the 511b gas had a 148 cid and the 611b had 188 cid I think. Bigger anyway. The 600 triple range ran at 2000 rpm but the COM ran at 2200 or 2250 rpm.
The 500 triple range ran at 1900 and the COM at 2100. The 600b was more tractor in about the same size package. Had taller rear wheels than the 500 too.
Wheat Straw
bradley martin
03-02-2007 09:42:26
The 611 was a case-o-matic and the 511 was the mechanical drive train
