PTO Housing Gasket
Kestrel CT
03-01-2007 08:08:01
third party image
Anyone have any leads for finding a PTO housing gasket that seals against the rear end on a VAI ?
Case p/n is VT 3528
John Saeli seems to have everything but this one.
Thanks guys.....
kestrel CT
03-01-2007 16:13:55
 Re: PTO Housing Gasket in reply to Kestrel CT, 03-01-2007 08:08:01
Much appreciated advice. I managed to find a gasket for $5.00 plus $8.00 shipping from a farm & antique tractor supply company in upstate NY, found 'em through Googling "Case dealers".
I gave the sales guy the superceded Case p/n (thanks Joe) and he had it. If anyone has some time to kill, you may want to check out their web site. Good therapy and interesting viewing for the late winter blues.
Link
Anyway, I've been using Permatex Ultra Grey Gasket maker IN combination with regular gaskets for my tranny/torque tube/
rear end work. Its supposed to be for high torque applications, but I like the idea of Cheerio boxes. What's a tractor project without a farmer fix anyway ?????
tom stanley
03-01-2007 14:19:29
bluegoo will work but remember guys silicon is dirt shows up that way in oil samples. if you use this use it sparingly!! have spent hours cleaning this junk out of passages pumps screens you name it I like to use 515 Case gasket elimnator made by Loctite if used right this has never failed me yet, just my advise mind you it works for me as I have to put a warrenty on my repairs it doesnt cause me grief later in some other areas as bluegoo can if over used
MikefromIowa
03-01-2007 13:39:44
I just used blue gasket maker when I replaced my PTO housing. Worked great!
J Heitkemper
03-01-2007 13:35:20
45 years ago I watched a neighbor Mechanic take a Cheerios box and a ball peen hammer ,, He punched a couple bolt holes thru for dowel pins and then tap-tap-tapped out the new gasket with the hammer ,, I use this method whenever I get in a fix such as yours ,,Add a little silicone,,let it tack up for about 15 minutes , And it will never fail you, And no one will ever know if you are running Cheerios or Genuine Case Parts or Saltines .. Good Luck ,Jim
mj
03-02-2007 15:16:53
 Re: PTO Housing Gasket in reply to J Heitkemper, 03-01-2007 13:35:20
What you said all except for the silly-cone; I went back to #2 Permatex after some mis-adventures with silicone over the years. :-)
Joe (Wa)
03-02-2007 16:27:22
 Re: PTO Housing Gasket in reply to mj, 03-02-2007 15:16:53
Dang cereal cost more than decent bulk gasket material and you still have to get rid of that crap in the box.
I heartily agree on the silly-cone.
Joe
dctom
03-01-2007 12:25:05
CILICONE WORKS FOR ME
Joe (Wa)
03-01-2007 08:29:31
VT3528 cross-ref nr is A30508 if you want to try a Case dealer.
I just buy some bulk 1/32" gasket material at an auto parts store and knock one out with a ballpien.
Joe
