greasing water pump on CC
Farmallb
02-27-2007 18:38:56
I am farming with my 34 CC. Now just starting spring plowing. will end up with around 25 acres under the plow. Im wondering how often I should grease the water pump, and how many shots with the grease gun. Im using a marine useage grease. Also, how often should I run a cap full of grease through the front wheel bearings.
Walt Davies
02-28-2007 09:18:07
 Re: greasing water pump on CC in reply to Farmallb, 02-27-2007 18:38:56
Your water pump grease is there to keep it from leaking thats why you need water proof grease the amount needed depends a lot of what grease you use.. just watch the pump if it leaks when the engine is not running then give a shot of grease just enough to stop the leak. to much grease won't hurt it but it is a waste of good grease.
Walt
