Gas vs. LP
keith jones
02-27-2007 07:28:58
Is there any difference in the intake port size or valve size from a gas head to a LP head? Are there any other heads that are interchangable with a DC that have larger ports and valves?
dboll
02-27-2007 10:55:19
 Re: Gas vs. LP in reply to keith jones, 02-27-2007 07:28:58
ex. valves on a 6128A (lp) are smaller than the intakes, 4570,5576, 5505 ect. in/ex are the same dia. and are about the same as the intakes in a lp head. ports are similar. You need to cc the chambers and figure comp. ratio with engine displ. I need 110 octane gas to run 331ci with a shaved 6128. this need s to be figured out before, a 5505 or 5576 should be adequate depending on intended displacement and comp. ratio, I like 10 or 11to1, engine parts will last longer at 9 or 9.5 to 1
