Two questions about the 630
Mikey
02-27-2007 06:05:46
When and why did Case stop manufacturing the 630?
itphillip
03-03-2007 20:17:01
 Re: Two questions about the 630 in reply to Mikey, 02-27-2007 06:05:46
630crazy is correct on both points. 1960-1963,and they were to small for a big tractor,and to big for a small tractor, thus case dropped the 630,at the end of 63"when they changed styling to the high-tank tractors on the larger tractors(7-830)(which would later become the comfort king)
Michael Hale
02-27-2007 18:37:15
My brother and I bought a rebuilt one last year. I like it. We then bought another which has a bad crank due to a spun rod bearing. This one I plan to fix up and use on my ten acres. I hope to get it moved from MO to KY in a few weeks. It is a diesel triple range lowgear. It has spinout rear wheels and adjustable front axle. I have seen they make crankshafts for around 600 bucks. I posted about another 630 I found that a guy who parts out and fixes tractors. I asked about it and he priced it. Now we will have 3. This 630 is gas and has a narrow front (trycycle). It has a hold in the block where it threw a rod. It is missing the carb,radiator, one front wheel, fender, and maybe the aircleaner. It has power steering. I don't know if I will restore it. Its serial number tag is gone. We will probablly use it for parts. Sadly it is a gas and I hear the crankshaft will not interchange. Does anyone know if the powersteering will work on a wide front? It is mounted in front of the radiator.
Michael Hale
PhilcaseinWPa
02-28-2007 07:10:31
 Re: Two questions about the 630 in reply to Michael Hale, 02-27-2007 18:37:15
My 630 has wide front end with power steering. I don't know if it is the same unit as on the narrow front ends. Where are you that you are finding all these 630s? They seem as rare as hen teeth around here.
Phil
Michael Hale
02-28-2007 19:05:53
 Re: Two questions about the 630 in reply to PhilcaseinWPa, 02-28-2007 07:10:31
Can you send some pictures of your powersteering unit. I'll take some of the powersteering unit on the narrow front parts tractor. Then we can see if they are different. My email is [email protected]
Stuart H
02-28-2007 13:46:18
Hi Phil,
The first 630 Mike (my brother) and I bought, a guy at work had it and had about completely rebuilt it. It has a couple things that need to be done, but it has about 6 hours on it now. It's a diesel, triple range, wide front. My brother found the trycicle gas burner while looking for parts and stuff. It had thrown a rod and the guy was parting it out. When we first looked at it, we didn't bother asking about it as we didn't think we might need anything off of it. But then Mike found the other 630 wich was a diesel, triple range with low gear and it has a factory loader... Well, I wanted that loader and we ended up buying the loader and tractor. Here in the next few weeks, we'll have it shipped down. So, after that, we went back and asked about the gas burner and the guy priced it and we're going to buy it. The one with loader is coming out of Mo. and the other two were within 60 miles of each other. I've seen a couple other cases, but they are not plentiful in this area. I haven't much experience with Cases and have not been around any others, but I really like the 630. It is a hefty tractor for it's hp and I like certain features of it. I was disappointed at first when I discovered it didn't have a live pto, but now I like the hand clutch and for what we will use it for, we'll have no problem with it. Feel free to drop Mike or I an email. We like talking and learning about the 630 and would like to hear any tips or possible problems we may run into and solutions for them.
Thanks,
Stuart
nate_schlief
03-27-2007 20:16:42
 Re: Two questions about the 630 in reply to Stuart H, 02-28-2007 13:46:18
A neighbor wants to sell his 630 diesel with triple range, 3-pt and wide front. I have a bunch of pictures if someone is interested in it. My email address is [email protected].
PhilcaseinWPa
02-28-2007 07:07:10
The diesel had 5 main berings compared to 3 for the gas engine. I have heard but don't know if it is true that the gas crankshaft can be machined between the 1 & 2 and the 3 & 4 pistons and used in a diesel. The blocks were 188 in both tractors. I threw a rod on my gas 630 and found another complete 188 gas engine for sale on this site that was real good. When I took the old engine apart I found a split nut from the broken connecting rod lying in the oil pan. I wonder what the sequence of events were when that rod broke?
John Noname
02-27-2007 17:38:09
Our dealer talked us out of one back then. He didn't like the engine, something about wet sleeves I think. Doesn't help sales when the dealer doesn't push them.
bradley martin
02-27-2007 07:19:21
I need to correct my earlier reply..I meant to type in l963 instead of"6l" ...sorry about that.
there may also have been some clutch and tranny concerns with the 630. I have 2 430 and the weak spot in them is the transmission so with the additional 30% hp (48 hp vs.34hp) problems might have been more frequent.
INCase
02-28-2007 05:28:52
 Re: Two questions about the 630 in reply to PhilcaseinWPa, 02-27-2007 07:11:47
I always thought the 630 and 730 were too close. A lighter 730 or heavier 630 would have been better but would have been expensive for Case to tool up from scratch. Other companies had the same issue in that 50 something HP range.
bradley martin
02-27-2007 06:30:08
The 630 shows up in the l961 Case Buyers'Catologue . Whether any new stock was manufactured that year or whether it was simply to liquidate inventory I am not sure. There was not enough difference in horsepower between the 530,630, and 730 to justify all three.
630crazy
02-27-2007 08:33:30
 Re: Two questions about the 630 in reply to bradley martin, 02-27-2007 06:30:08
The last year of production was 1963 but were sold in 1964. I think the tractor just fell in the middle and sales dropped, it"s too small for a big tractor and too big for a small tractor. I love mine... just right for what I need it for.
