What is the most fast case tractor made
Sunny 4 acres
02-26-2007 10:54:44
I was wondering out of all the case tractors what one had the fastest road speed. My 430 diesel skoots right along but was wondering if theyre is a faster one.
Docter
03-01-2007 04:23:04
 Re: What is the most fast case tractor made in reply to Sunny 4 acres, 02-26-2007 10:54:44
i got a 57 311 and i was clocked by roadside radar at 29mph i was pulling a load of logs in 3rd gear in hi range going up a slow grade. wish i had a camera it was funny to see the speed in lites like that for a tracter my son was sitting on the logs laffin
Dave Beiter
02-28-2007 08:35:20
I have a 1960 530 diesel triple range that will run a good 35 mph... my 211B I have not tried.... my VAC 14 tops out around 11mph
Walt Davies
02-27-2007 13:18:02
I had a 43 SI that would fly in 4th never did test it out or clock it was alway scared to open it all the way up. when going from 3rd to 4th you had to cut to idle or be ready to jump off.
My uncle Walter had a 48 orchard model and said it would do 30 in road gear.
Walt
John Noname
02-26-2007 18:07:26
The 300 round nose with 34" rears clocks out at 35 mph. It cost me a few bucks to find this out as the friendly police clocked me in a 25mph zone.
JGarner
02-27-2007 08:58:10
 Re: What is the most fast case tractor made in reply to John Noname, 02-26-2007 18:07:26
That has to be one for the Guiness book of world records... a speeding ticket on a farm tractor!!!!!
jaker1
02-26-2007 18:04:57
We have a 211-b that on the flat runs 32 mph. It takes a few up-shifts for it to get there. That 126.5 cu inches is working for all it is worth to get there.
Joe (Wa)
02-26-2007 11:51:04
I have a '53 VAC w/road gear that clocks 35 mph on the flat and a '56 310 w/road gear & triple range that runs about the same in direct drive, haven't tried it in high range, not going to either.
Joe
mj
02-26-2007 16:34:59
 Re: What is the most fast case tractor made in reply to Joe (Wa), 02-26-2007 11:51:04
What's the deal with the Vac, Joe? 3,000 RPM, 32 in. rears and 28" gears or what?
Joe (Wa)
02-26-2007 17:39:09
 Re: What is the most fast case tractor made in reply to mj, 02-26-2007 16:34:59
Don't know mj. Drove it home about 8 miles, son following, clocked on his pickup @ 35. Don't know the rpm, didn't check or setup until I had done the some engine work, vl grind, carb, dist, the usual things right after you buy one. Gov didn't work, still doesn't very well, not worth pulling the timing cover for what I use it for.
VAC-13, 28" rear, 600-16 front. Has a low profile shifter like you see on a VAC-14. Posted this once before, response was that it probably has a VAI transmission.
Joe
mj
02-26-2007 21:59:38
 Re: What is the most fast case tractor made in reply to Joe (Wa), 02-26-2007 17:39:09
What I've been thinking about is swapping the final drive gears from a VAO w/24" tires into a VAC w/32 or 34" tires to get some road speed for those 'tractor drives'. The VAO with 10-28s makes 12 1/2 mph while the VAC with 10-34s is listed at 11 2/3 mph. So if you had the gears for the shorter tires and then ran the tall tires ???? ..... . Right? Or am I seeing things in the parts book that aren't there?
Joe (Wa)
02-27-2007 11:11:05
 Re: What is the most fast case tractor made in reply to mj, 02-26-2007 21:59:38
mj, you have considerably more knowledge & experience in VA series tractors than I. I bought this tractor about 8 years ago and that is the last time it has been driven on a flat, paved road that will accommodate any speed higher than about 10 mph. That road stretch is about 4 mi from my property.
When I drove it home it reqd full choke to idle and could be eased open as the ground movement picked up. That problem was a blown intake manifold gasket, not fuel restriction. So yes, with that and a nonworking gov, it likely was running higher than design rpm for a VAC.
I don't know about the VAI transmission advice I got here, but it does have a higher speed ratio than any VA that I have driven. It could be a VAC-13 mower transmission per parts cat R.E. E61, pages 60 - 63 but haven't tried to figure out the difference in ratio. I did set it up at the VAI no load 1950 rpm for power in lower gears as I was using it to drag large stumps when clearing the house site on my property.
Joe
TomVAC
02-26-2007 18:09:52
When i worked at a Case dealer 20 some years ago they talked about how the VAC"s were demonstrated from farm to farm by Case reps. They were driven with a wagon behind with implements on it. They would swap the governor spring with a brake spring. They claimed the dip stick would break off from the vibration. One time a VAC trade in was driven to the dealership this way. The customer couldn"t believe his eyes. Back to the subject I found the fastest Case would be a round nose 300. Make your eyes water with the wind.
wayne2
02-26-2007 19:22:10
 Re: What is the most fast case tractor made in reply to TomVAC, 02-26-2007 18:09:52
My round nose gets scary-espically after loosing f-bearing and replacing with something close(death-wish) LOL W
BarryfromIA
02-26-2007 19:19:55
Are talking factory stock or anything goes? A 630 with triple range should be fast because the rpms were set higher than a 300.
D13
02-27-2007 13:46:30
 Re: What is the most fast case tractor made in reply to BarryfromIA, 02-26-2007 19:19:55
430 triple range diesel with 16.9-24 turfs on it. 16+MPH at part throttle in direct 4th, was afraid to run 4 high cause unable to steer (very bouncy on unbalanced tires). Cost some clutch to get it rolling but a wild ride.
