case va 4 civil defense again
tim coltman
02-25-2007 08:51:59
hi i got it home last night it has an anderson snow plow frame on the front model # R42 anyone have any info about that? the serial number of the tractor is AISC53486 it was on the dash under the steering column. i coudnt find a tag on the cab though but it definatley looks like it was made for the tractor. can anyone tell me more about this thing looks like a neat tractori would like to get it fixed up this summer and painted correctly what color should it be? i have a ton of questions about it. but that is it for now.
'53 VAI Guy
02-28-2007 20:37:08
 Re: case va 4 civil defense again in reply to tim coltman, 02-25-2007 08:51:59
I agree with Joe as well. The Serial Number you gave is inconsistent with any Case Number I have heard of. I had to clean several layers of paint off of my dash tag to read it as well. I bet you will find that it is a "VAI50....." indicating it is a 1946 tractor (subtracting 4 from the first two numbers). Good luck.
Jerry W
02-26-2007 06:48:19
I love VAC"s and it looks like a really neat old tractor. Usually if it is governmental issue there will be a supplemental tag on it somewhere for such things as "how to lift", "oils and service". Regardless if it is government or not, that cab is really neat.
I have a VAC13 that has a brass tag on the right cowel cover and it shows the lifting points of the tractor and I wonder if it was maybe Corps of Engineers although it does not say anything about the agency that might have ordered it.
Just curious, where did you get the designation VA4? Jerry
tim coltman
02-26-2007 18:59:46
 Re: case va 4 civil defense again in reply to Jerry W, 02-26-2007 06:48:19
thats what the guy told me it was i do plan to restore it. anyone know where a tag that would say something about military on it would be havent got a chance to look real close at it yet gonna try to pull it into my shop tommorow and get a better idea of what im getting myself into. also is there anyplace i can find out about where it was made or a websie for war tractors. i am positive it is one the guy i bought it from also had a moline that was it had some government tags on it he used to import used military equipment i guess.
dboll
02-26-2007 06:34:31
If it was a civil defense tractor I would definitely restore it as such with proper insignia, the same as I would do with one of those SI airborne tractors if I ever get one.
wheat straw
02-25-2007 16:47:00
Tim, you've got a vai with some interesting after market features which makes it very desirable in my opinion. That cab would make it neat for winter feeding.
Wheat Straw
Joe (Wa)
02-25-2007 11:29:51
Just a shot in the dark, is the model/serial nr tag clearly stamped? Tractor is VA series, appears to be a model VAI, and should have a seven digit serial nr.
AISC53486. Look to the left of the "A" for a "V", could be partially hidden by the left side tag screw. The "SC" in your nr may be digits, possibly 50. That would make it VAI5053486 as in a 1946 VAI.
Also look for the engine serial nr stamped into the block above the starter just below the cylinder head gasket. That serial nr probably starts with the letters VAB or VAC. Example VAB-124-#####.
Just my take on it.
Joe
tim coltman
02-25-2007 08:53:13
third party image
here is a picture
