case sc parts interchange?
911oldschool
02-24-2007 19:33:57
I have Posted a few times before. I have not been able to get "Down and Dirty" with my SC yet... I am still trying to find parts(reasonable). Are there other Makes / Models that will interchange with my 50 SC? IE: engine parts, etc.
C. Amick
02-26-2007 09:28:58
 Re: case sc parts interchange? in reply to 911oldschool, 02-24-2007 19:33:57
You may want to check the serial number on your engine block, but if it was made before Serial Number 8027114 new replacement sleeves, pistons, and rings are available from a number of sources. The serial number should be stamped on the outside edge of the block flange where it bolts to the bell housing (left side, I think). Used sleeves are usually badly rust pitted on the exterior which makes it difficult to get the "O"-ring to seal.
911oldschool
02-26-2007 15:40:00
 Re: case sc parts interchange? in reply to C. Amick, 02-26-2007 09:28:58
will check in the AM when i can see it. thanks alot
911oldschool
02-25-2007 13:44:07
number 2 and 3 piston sleeves destroyed... probably also the the rings.... have yet to be able to get them out.
Elton Fancher
02-25-2007 06:14:39
I have a couple of SC tractors, a 49 and a 50 if you need used parts I might be able to help.
Caseman-d
02-24-2007 20:32:56
Most all S series engine parts will interchange. Some combines had the S series engine in them, Then there are SE power units. What parts you looking for?
caseman-d
