37 Case CC front wheel bearings
Tractor Hank
02-24-2007 17:13:12
I am installing a set of steel front wheels on my 1937 Case CC to match the rear steels and bring it back to original. The front steels I was able to buy have some slight pitting on the bearing race in the wheel. Will this hurt as this will only be a parade tractor or is there a way to repair this. The old bearings out of my old wheels are in perfect condition.
dboll
02-26-2007 06:37:02
 Re: 37 Case CC front wheel bearings in reply to Tractor Hank , 02-24-2007 17:13:12
pressed in, seals the same up to the 30 series
DKase
02-25-2007 05:26:34
When I mounted the steel on my D there were no races or bearings in the wheels. I simply knocked them out of the rubber tired wheels and put them in the steel.
flying belgian
02-24-2007 18:58:59
No for what you are using it for that pitting won't make any differance.
tractor Hank
02-25-2007 05:43:24
 Re: 37 Case CC front wheel bearings in reply to flying belgian, 02-24-2007 18:58:59
Does anyone know if the front wheel bearing races are removable. Are they pressed into the wheel or are they part of the front wheel?
