dc brake latch
johndeereman
02-23-2007 12:40:49
i see there is a whole drilled in the brake latches on the dc"s im too fat to bend over and set the brake and latch did case have a set up for this, seems like you could take a rod and run it up from the latch but i dont know where it would set by the seat. thanks
Newton Miller
02-23-2007 14:50:24
 Re: dc brake latch in reply to johndeereman, 02-23-2007 12:40:49
we had several DC's on the farm. we had a wire on each latch worked good
Nedd
02-23-2007 13:37:03
We had a couple DC's we parted out over the years that had a very light/small chain fastened to them and through the hole in the seat bracket. I assumed those were factory. I went out and looked at my 2 DC's and neither had them on. But rope will work just as good.
dctom
02-23-2007 12:55:53
I TIE A SMALL 1/4" ROPE ON ONE THAN THREAD IT THRU THE SEAT BRACKET AND TIE IT TO THE OTHER ONE CAN WORK BOTH LATCHES WITH IT THAT WAY, A ROD WOULD BE CLUMSEY TO SAY THE LEAST TOM
Graham of NZ
02-23-2007 13:20:21
 Re: dc brake latch in reply to dctom, 02-23-2007 12:55:53
We had a DEX here new (Nov 1947 SN# 5100220 DEX) It had full wheel guards including a flat sheetmetal guard betweel wheelguard and the tranny housing and from axle housing to front of guards. this covered up all the area over the brakes. A 1/4" or 5/16" rod went from the hole in the brake latch (each side seperately) and through a corresponding hole above in the flat guard to pull up to lock brake. I'm sure a light rope (probably baling twine!) through the hole and up to the guard or light bracket would do just fine.
