Case LA Head
Theodores
02-22-2007 04:46:32
Greetings!
I have a 51 Case LA that had steam coming from the radiator really bad. It ran great, just steamed massive amounts from the cap - you could hardly see the tractor. I tried the vinegar trick recommended on this website with no luck. Radiator is good - so I went to the next step which was the head. After removing the hood, I have discovered about a 5 inch crack in the top of the head on the outside. Though I never saw water coming from here before, it is an obvious crack to see after the hood is off. My question is, does this pretty much mean this head is shot? Are these heads hard to find/expensive? Is this a common problem on the LA head. Thanks for your help in advance!
tomstanley
02-22-2007 06:25:57
 Re: Case LA Head in reply to Theodores, 02-22-2007 04:46:32
some people weld them I would look for a good one not hard to find around here am in NE WYO might check with ELSON Implement in SD 6058922795 no this is not that common would guess it has been run low on coolant also check water pump impellers lot of folks ran these with water only somtimes is corrosiveto these parts also recomend checking sedimate build up in area around sleeves have seen this cause heating I have seen this cover most of sleeve before makes them warm up quickly and not be able to remove heat from cylinder area if Curt Elson is out of heads post me a message here I have or can find one easy enough tom.....
