300 power steering
kyle boettcher
02-20-2007 19:27:46
Does anyone have a power steering unit for a 300 general purpose? Should consist of pump and reservoir as one unit that runs off the cam gear with two steel lines that run to a char-lynn booster motor that is mounted in the steering shaft. If someone has one I would like to have it. Thanks
J.Blahitka
02-21-2007 14:52:44
 Re: 300 power steering in reply to kyle boettcher, 02-20-2007 19:27:46
Hi Kyle I know were you can find a power steering unit. Look in the case 300 series tractors parts catalog R.I.A324 page144.It's the only place that I have ever seen one. LOL. GOOD LUCK. I have been looking for a long time. Please post and let us know if you find one.
BarryfromIA
02-21-2007 15:39:31
 Re: 300 power steering in reply to J.Blahitka, 02-21-2007 14:52:44
Hi folks. Get a pump from a 600 or 660 combine that is is parked, or a junked CASE utility tractor that had a loader. Baum Hydraulics lists the Char-lin shaft unit. The pump CASE used is a Barnes Co unit.
