need help 930ck hydraulics
jones farm
02-20-2007 14:39:00
any one tell me what involved in rebuilding hyd. on 930 and where is pump is located
DKase
02-20-2007 20:43:50
 Re: need help 930ck hydraulics in reply to jones farm, 02-20-2007 14:39:00
Tom has it right if you have a 8 speed. If you have a 6 speed the pump is part of the valve assembly. It is mounted on the front of the valve and is very expensive to work on. You will need bearings, shafts, gears, and wear plates. I priced these parts for my Eagle Hitch 830 2 years ago and the total came to well over $1000 at that time. Hoping you have a 8 speed DK
tom stanley
02-20-2007 18:46:17
pump is on rear above pto square housing with hyd line coming out right hand side as veiwed from rear of tractor pump is aluminum and needs to be rebiult by hyd shop I buy the reman units from case they usally last around 3000 to 5000 hrs on my units I always change filter and clean and or replace suction screen this is accessed buy removing pto unit be careful to not damage screen I like to balance pto unit buy putting short pipe over pto shaft to keep unit vertical when installing and removing also install two studs in retain bolt holes to help with alinment can make these from a 6 inch bolt with head cut off if you can borrow or have a flow tester check specs on pump first a lot of times poppet check in hyd valve is bad not pump most units require fuel tank removal to get valve off if you need specs on hyd post me a note my e-mail is still down hope this helps Tom
jones farm
02-21-2007 06:05:24
 Re: need help 930ck hydraulics in reply to tom stanley, 02-20-2007 18:46:17
thanks tom//d kase..helps alot.. im a jd man dont know a lot about case tractors, and it is a 8 speed 930ck diesel
jones farm
02-21-2007 06:04:40
