Case plow question
Scott KY
02-19-2007 19:13:26
I have a Case BER three bottom eagle hitch plow. It has a turnbuckle from the top of the A frame down to the frame of the plow. I understand this controls the depth the plow runs. On the cover of the spring 2006 issue of Old Abe's News there is a DC with a 3 bottom mounted plow but it doesn't have a turnbuckle. Looks like a flat piece of metal instead. What is the difference in these two plows?
c hess
02-20-2007 19:27:44
 Re: Case plow question in reply to Scott KY, 02-19-2007 19:13:26
Ithink you could put a hyd cylinder on an adjust with cylinder. If you look closely there is a curved end with cylinder mounting hole an could be used WITH CYD . Had a2 bottom on a sc but did not use cylinder.
