Case Model D
Jim Wooley
02-18-2007 18:55:03
I would like to know the wieght and width accross the back wheels of a 1950 Case Model D.
thanks for your help.
Jim
Mathias NY
02-19-2007 04:38:07
 Re: Case Model D in reply to Jim Wooley, 02-18-2007 18:55:03
I have a 1949 'DO', essentially the same as a D. It has 13-26 rears, one is loaded, no hydraulic pump. With one cast weight on each wheel, it weighs in at 5580. Probably 5094 without the calcium in one tire.
It measures approximately 60" to the outside of the rear tires.
Fergus
02-19-2007 03:09:34
Jim, I have a 1953 "DO" that had to be stripped of the hydraulic assembly, cast air cleaner, and factory drawbar assembly to get below 5000 lbs with me on it. Native weight when normally equipped will fall around 5300 depending on tires, etc. Tread width is more narrow than almost anything in the row crop category, don"t have it here to measure. This compact looking tractor will put a lot more power on the ground than one might expect.
