dctom and others - question
todd hamilton
02-18-2007 06:06:59
Where can I get a thermostat to fit in the hose on an SC? I tried one for a Ford N series from TSC but it is a smaller diameter. I put a layer of hose around it but it still turned sideways and restricted the water flow. I am back to running with no thermostat for now but engine will not warm up in this cold Indiana weather. Thanks - Todd
Mathias NY
02-18-2007 12:29:40
 Re: dctom and others - question in reply to todd hamilton, 02-18-2007 06:06:59
I use the poor-man solution: cardboard over the front of the radiator. It won't warm up as much, but a lot better than nothing.
John Saeli
02-18-2007 08:32:24
We keep 1 in stock. We make them like Tom says.
dctom
02-18-2007 08:28:09
TODD, I DONT KNOW BUT IF I WANTED ONE I WOULD BUY ONE THAT IS BIGGER AND THAN TRIM IT TO FIT TOM
todd hamilton
02-18-2007 11:48:11
 Re: dctom and others - question in reply to dctom, 02-18-2007 08:28:09
So are you saying that it is your preference to run without a thermostat? (which I have done for years - just want it to warm up better in cold weather) The Ford N series is the only "in hose" thermostat that I have seen. If you take a regular thermostat and trim it down how do you keep it from turning in the hose when it heats up and expands?
Bruce Nelson
02-18-2007 15:05:54
 Re: dctom and others - question in reply to todd hamilton, 02-18-2007 11:48:11
Todd, you can hold the thermostat in place with a clamp around the outside of the hose. I solder my SC thermostats to the inside of an old cam bearing to give the hose clamp more to clamp onto. I think one from the auxiliary shaft in a 2.3 Ford works just about right. Any local engine rebuilder should have a bunch of removed bearings around, just find one that will fit snugly in the radiator hose. You could probably otherwise find a short piece of steel or copper tubing to do the same thing. Drill a couple 1/8" holes in the thermostat, otherwise without a little coolant flow, (from the drilled holes) the engine will get a lot hotter than the thermostat is rated for before it will open up, as the thermostat will be a little ways away from the head. Put the thermostat in the hose as close to the head as possible to assure it gets as close to the heat source as possible. Put a radiator hose clamp around the outside and you will have a nice warm and happy SC. Bruce
todd hamilton
02-18-2007 17:11:04
 Re: dctom and others - question in reply to Bruce Nelson, 02-18-2007 15:05:54
thanks - I didn't think of sleeving it with something metal.
