Dctom Would you look at post and see what you thin
Nicholaus Sowde
02-17-2007 17:47:11
Dctom Would you look at post and see what you think it wrong with my Dc? I need help with my Dc. Yesterday I tried to start it and it seems to flood to easily. When cranking it would push air out of the bottom of the carburator where the nut with a hole in it is. It also has a leak between the carburator and the manifold. I haven't started it in while. What could be wrong? The last time I started it I had charged the battery for a while and it started right up. Thanks
dctom
02-18-2007 04:15:37
 Re: Dctom Would you look at post and see what you in reply to Nicholaus Sowder , 02-17-2007 17:47:11
NIC, THAT LEAK BETWEEN CARBUATOR AND MANAFOLD IS A NO NO, ENGINE IS SUCKING AIR THERE AND NOT UP THRU CARB LIKE IT SHOULD, AND MAYBE LIKE POSTED BEFORE VALVE STUCK OPEN WONT HELP EITHER TOM
