question on 930 CK 6 spd vs. 1030 engine swap
SupC
02-16-2007 20:27:12
Dboll had said that the chain drive clutch housing wouldn't match up to a gear drive engine.I'd like to get a little more details on this, like will any of the clutch housing to engine block bolts will match up, or are they all off from each other.Any more details/help from dboll or anybody else would be appreciated.Thanks!
itphillip
03-03-2007 21:01:40
 Re: question on 930 CK 6 spd vs. 1030 engine swap in reply to SupC, 02-16-2007 20:27:12
you cannot interchange a 6speed with 8speed, a 6spd is chain drive(wet-clutch)8spd is dry-clutch engine lenghts-9&1030 are the same, difference is 1030 have an extra inch in the front-end housing (where radiator sets,&weights bolt to.) did you know a 1030 hood is an inch longer than a 930,its in this front housing. last-your 1030 motor will bolt to almost all case tractors bellhousings with dry cluthes.
I have big 400 rearend bolted to 2670 block,+ 930 w/2470 motor,+1030 w/1470 motor. they boltup easy,its all the other little things that get tuf
dboll
02-20-2007 05:09:10
504 block is shorter and the starter is in a different location than the chain drive block, it is not a bolt in deal, a friend made an adapter and would maybe make another for the proper$$, I wouldn't post this stuff if i wasn't pretty certain of accuracy!
Thad
02-17-2007 05:41:36
Doug is correct a 930 6 speed has a diffrent bolt pattern than any 8 speed. The bolt pattern on a LA thru the 930 6 speeds is the same. When they went to the gear drive rear instead of the chain drive is when it changes. As far as length all 4 cyl gear drives are the same and same goes for the 6 cylinders. If there is any diffrence its less than a 1/8 of a inch. As far as if any of the bolts might match i cant say on that one. I have never tried to see if any are even close to matching. Im sure with enough time and money spent someone could make one fit. But it wouldnt apear stock anymore. Thad
Camboted
02-17-2007 02:22:17
Doug's usually right, and I'm not that sure about the 1030, but I'm pretty sure the 930 8 speed tractor is the same from the bell hosing back, and those engines interchange with the six speeds, We've seen 930's with power kits that must be close to the 1030 size. As far as the length goes,(the 1030 is a six cyinder 830, and the 930 is a six cylinder 800) if it is longer, it's not much different, it really is just a matter of the hood and steering shaft, not a big deal if you can weld. My guess is that you could bolt it in, but make sure first. LOL!
Camboted
02-17-2007 05:00:33
 Re: question on 930 CK 6 spd vs. 1030 engine swap in reply to Camboted, 02-17-2007 02:22:17
I forgot to add that the crankshafts interchange between the 930 and the 1030, so I really think they are the same length and will both up.
Phil Munson NY
02-18-2007 07:15:47
 Re: question on 930 CK 6 spd vs. 1030 engine swap in reply to Camboted, 02-17-2007 05:00:33
I have contemporaneously had a 930D 8 speed and 1030D 8 speed. When changing the belly mount 400 gallon sprayer tanks from the 930 to the 1030 the mounting holes had to be lengthened about 2". best Yeoman
Phil Munson NY
02-16-2007 23:25:53
The block of the 1030 is longer. EVERYTHING is going to have to change to accomodate that.
