VAC Fluids
Dennis Priestle
02-14-2007 18:15:54
I've spent the last 48 days wire brushing, cleaning,and repairing as needed a 49/50 VAC. Now its time to fill the fluids. Because the Hydrulic and rearend fluids are seperate, I assume they require different oils. I assume the rearend takes 80W90 and SAE 20 for the Hydrulic. Am I correct in making these assumtions.
mj
02-16-2007 19:55:13
 Re: VAC Fluids in reply to Dennis Priestley, 02-14-2007 18:15:54
The 80-90 will work in transaxle and torque tube if you have the low-pressure hydraulic system; if you've got the hi-pressure system put 80-90 in the torque tube as well and the 20W in the belt pulley housing. Original specs call for 90w but they didn't have 80-90 then. I run 5w-30 in all of mine in the hydraulics whether they're low or hi-pressure. Click the link for more.
