730 shimmy
Mike Foussard
02-13-2007 19:11:55
Hi, I have a 1965 case 732c (730 western special with com) with a terrible front wheeel shimmy. LOCAL DEALER HAS REBUILT the ross side cylinder and pump. The manual steering box has had all bearings replaced and adjustments made. The steering shaft u-joints are also new. TRACTOR IS DANGEROUS at speed! Any insight would be appreciated. Thanks
flying belgian
02-14-2007 06:22:27
 Re: 730 shimmy in reply to Mike Foussard, 02-13-2007 19:11:55
had a 700 with same problam as Nedd. drill a 1/4 hole down spline and drive a 1/4" pine in. saw access pin off an put cap back on. It is an easy and efective fix.
Nedd
02-15-2007 05:53:35
 Re: 730 shimmy in reply to flying belgian, 02-14-2007 06:22:27
Thought about spot welding it but your idea sounds better. Thanks
Jim B.
02-13-2007 20:14:54
Assume your 730 is a wide front end. If so, adjust the wheel toe-in more inboard at the front of the wheel. Had the same problem on my 800 and the adjustment fixed it. I believe as our Ol' girls wear there needs to be excessive toe-in to drag the tires down the road as little sideways to keep the worn components tight to one side.
Nedd
02-14-2007 05:45:42
 Re: 730 shimmy in reply to Jim B., 02-13-2007 20:14:54
Have an 830 with a wide front end. It is loose on top of the spindles. The splines have worn in the casting and causes a wicked "shimmy".
