DC Case carburetor bolt
RonSa
02-13-2007 13:08:00
To tighten the inside (upper) 5/16" carburetor bolt that connects the carburetor to the air cleaner, no standard wrench or small socket seems to work for me. I radially thinned down the jaws of an open-end 1/2" wrench but still that does not work. I am curious what innovative ways or special wrench others have used to tighten this bolt.
RonSa
02-15-2007 09:01:12
 Re: DC Case carburetor bolt in reply to RonSa, 02-13-2007 13:08:00
Thanks for all you input. I like to put a gasket at that joint because it is cleaned air and I like to tighten the upper air cleaner joint and two carb joints simultaneous to avoid stresses on the carb ears. To do this, my only success has been to stick the open-end wrench from the front between the carb and block at an angle onto the hex and twist on the other end of the wrench. This gets me about 1/12 of a turn and then I can usually get another 1/12 of a turn using the open-ended wrench normally. This advances the bolt one flat. Disgusting task!!!
Don L.
02-14-2007 18:26:47
I have never liked that bolt position. Never.
Don L.
dctom
02-13-2007 16:50:07
NO PROBLEM JUST LOSSEN BOLT UP THU THE MANIFOLD THAT HOLDS AIR CLEANER SWING IT OUT AND TIGHTEN BOLT THAN SWING IT BACK AND DRAW IT UP BOLT CARB TO INTAKE, PIECE OF CAKE
JHeitkemper
02-17-2007 17:56:50
 Re: DC Case carburetor bolt in reply to dctom, 02-13-2007 16:50:07
Gosh , Tom ,,, I will try that next time ,, Now That seems so simple .. Thanx for the try on the info for the early 45 DC ,I was not sure if you had cards or not , Really do not know what We have there ,, Wilson was looking for different gears ,, Thanx ,Jim
Don Rudolph
02-13-2007 16:35:49
I am so happy to hear that other people have the same problem! Not one of Case's best designs, but a minor flaw at that.
Tom Railsback
02-13-2007 14:27:03
THe easiest way I have found is to take the piece off the air cleaner and tighten both bolts then attach the carburetor to the intake manifold.
