Marvel Mystery oil dispenser on VAC
JRT
02-12-2007 19:50:19
I was looking over my new VAC I brought home today and there is an extra little tank attached to the left side of the hood with a little metal tube running from the tank to the intake manifold. On top of the tank it says "Marvel Mystery Oil dispenser" or applicator, or something to that effect. The letters are so small it is hard to see. Anyone else ever see one of these on a motor? How did they work?
kestrel in CT
02-15-2007 19:27:13
 Re: Marvel Mystery oil dispenser on VAC in reply to JRT, 02-12-2007 19:50:19
Like the '47 Desoto mentioned, I had one on my 1950 Dodge Coronet and she ran like a top. Also referred to as a top cylinder lubricant dispenser and was considered "period equipment" by the judges.
A pretty looking thing that also served as a great conversation piece at antique car shows.
C. Amick
02-13-2007 09:17:45
Better check the oil filter. One reason to put one of these upper engine lubricators on a VAC is if the hollow oil stem that slides up into the top of the oil filter is missing. The upper engine "will not" get lubricated, if this stem is missing. Older tractors such as the Case "C" Series were supposed to be manually lubricated, so one of these lubrication units would be beneficial for one of these tractors. There is a company that still makes lubrication units. I can look up the name, if interested.
mj
02-13-2007 17:11:30
 Re: Marvel Mystery oil dispenser on VAC in reply to C. Amick, 02-13-2007 09:17:45
How does not having the 'stem' in the oil filter affect the oil flow to the head?
Joe (Wa)
02-13-2007 21:33:37
 Re: Marvel Mystery oil dispenser on VAC in reply to mj, 02-13-2007 17:11:30
My '53 dropped about 2 psi (15 to 13)@ op temp under light load with the stem tube missing. Normally the oil press stays at 15 psi working hard on a hot day. That drop indicates that the oil pump has run out of reserve capacity to overcome the filter media by-pass.
Yeah, it still pushes some oil up to the top deck for the running gear which would probably survive with little more than a mist at light load. But at heavy load and higher oil temp the oil volume is going to continue to drop when you need it most. Also the center and aft cam bearings are lubricated by the return oil run-off from the top deck.
You already know this mj, am I preaching to the choir?
Joe
C. Amick
02-13-2007 19:26:40
The oil seeks the path of least resistance. Without the stem with the small holes in it inplace; instead of pushing on up into the head, large quantities dumps into the bottom of the oil filter housing and runs back to the crankcase.
other Will
02-13-2007 08:23:45
Friend had one on a 1947 DeSoto car. He called it a top lubricator. Said it kept valves from sticking. I've never had trouble with valves on my 48 Chrysler without a top lubricator.
