To DCTom and TomRailsback
Fillroy
02-12-2007 16:13:57
Tom and DCTom,
Block casting Number is a 9569A Right rear top of block has a C384396
Transmission housing in front of drain plug under neath tractor has a 9-26 over 38 It does have what appears to be an oil pressure regulator valve left front of block
If it will help any I can give all the casting numbers on the drop housings and spindels.
Thank you guys for all your input
Fillroy
Tom Railsback
02-12-2007 17:39:35
 Re: To DCTom and TomRailsback in reply to Fillroy, 02-12-2007 16:13:57
The parts book shows the part number for the C series block as 4569A not 9569A; is it possible you misread it? A date of 9-26-38 would indicate CCS too. Sorry Tom, I think I got this one.
dctom
02-13-2007 07:12:18
 Re: To DCTom and TomRailsback in reply to Tom Railsback, 02-12-2007 17:39:35
NO PROBLEM TOMMY, ONLY THE SECOND TIME I HAVE EVER BEEN WRONG LOL I AGREE NOW IT IS A CCS DCTOM
Fillroy
02-12-2007 17:44:51
Is the C384396 (stencil number in block) the serial number for the tractor?
Fillroy
Tom, this is Fillroy's wife, I mistyped the casting # it is in fact 4569A. Sorry
Tom Railsback
02-12-2007 17:51:52
 Re: To DCTom and TomRailsback in reply to Fillroy, 02-12-2007 17:44:51
That very well could be the serial number, but, if it is, the block has been changed because that number is from a 1930 tractor and CCS's were only built in 1937 and 1938.
dctom
02-12-2007 16:35:48
IF IT IS A C SERIES IT WILL HAVE A SERIAL NUMBER STAMPED ON A BOSS AT TOP RIGHT OF BLOCK IF IT IS A D SERIES NUMBER WILL BE ON ENGINE FLANGE BEHIND AIR CLEANER, CASTING NUMBERS DONTMEAN MUCH TO M E TOM
