4890 steering
coreyc
02-12-2007 13:03:36
I have a 4890 that the rear wheels will pivot erratically sometimes. The front and rear sensors check out ok. I have hooked the dioagnostic box up to the tractor and everything checks out ok. Any ideas?
dwag
02-14-2007 07:21:20
 Re: 4890 steering in reply to coreyc, 02-12-2007 13:03:36
Clean up and center rear steer valve. Slightly decrease sensitivity adjustment at control panel. Check grounds as others have suggested.
4 R's
02-14-2007 07:03:31
Forgot to mention, every wire that needs to be grounded make sure it is grounded. Dad stayed mad all day yesterday b/c steering was in and out for the rear. at the end of the day it was just the ground wire that needed tightening.
4 R's
02-14-2007 06:50:21
totally redone the fuse box on our 4890 like john said, also make sure the sensors are the correct ones, dealer gave us the sensor for the back of a 4690 and it was to short so back tires would rarely respond.
John Saeli
02-12-2007 16:53:56
I had the same problem with a 4690 & the problem was with the fuse holder tucked away in the console.
