need more info
johndeereman
02-11-2007 15:56:36
im planning on reworking the head on my dc everyone says can go 100 thou. well i dont know if its been done before the water jacket measures 5/16 th"s of an inch also are both the intake and exhaust valves both 45 degree angles also if i shave the head as far as i dare can i also use a copper gasketim not sure what pistons i have i can see they are flat tops they look like they come right up to the top of the block oh and im using the 5576a head pot and polished . hope to get a couple of trophies in the farm stock class this year lol.
johndeereman
02-12-2007 16:46:55
 Re: need more info in reply to johndeereman, 02-11-2007 15:56:36
im thinking of a copper gasket just to get more compression 15 tho verses 90 thou
dboll
02-13-2007 05:06:24
 Re: need more info in reply to johndeereman, 02-12-2007 16:46:55
then I would go to a 5505 head or a 6128 propane, copper gaskets are a pain in the a$$
dboll
02-12-2007 12:55:30
we shaved one until the outer chambers were gone, 45degree angle x2, stock head gasket works up to 4.5 bore and alot more comp. than you will have with oem pistons, I need to run 110octane gas and haven't blown one yet.
