need some info?
casemannot
01-16-2006 22:44:06
My Dad found a Case 1940's or 1950's Patent #1761014 Serial#11716DC Eagle case Mag #78420 Block#427 the motor is stuck need to get some info on what Model & actual year this case is & maybe some idea's to unstick the motor i do know not to pull it and is it worth 500.00 i know alot of questions sorry thanks
toomanycases
01-17-2006 00:18:28
 Re: need some info? in reply to casemannot, 01-16-2006 22:44:06
Hi, you are missing some numbers on it. Serial number should be 7 numbers. First one may be hidden by the rivet, or check on left side of engine where block & trans housing bolt together, number should be stamped along the edge of the block.
