Engine parts for a 1957 Case model 509
Randy Dillard
02-11-2007 09:15:46
I'm looking for a new radiator core for a Case 509. Haven't had any luck finding anything other then a manual so far online.
Thanks
K Dillard
02-12-2007 16:32:50
 Re: Engine parts for a 1957 Case model 509 in reply to Randy Dillard, 02-11-2007 09:15:46
iwas just looking at the letters and found another case fan dillard. i have a 351 case. i was just wondering what part of the country you where from. im in tn.
DKase
02-11-2007 13:56:10
Do NOT look for 500B. What you have is a power unit that is the same as the engine in the 500 tractor with the big 6 cyl. engine. The 500 tractor did not have a pressureized radiator. If you cannot find anything for the 500 tractor, do some measuring and comparing of the core size. It might be the exact same thing as the LA. The 600 has the exact same engine as the 500, but it had a pressureized radiator. I would start there because it would be a radiator designed for pressure. Don Livingston has a 600 and he might be able to get a core for you. You can reach him at 507-433-0073 before noon every day. If this does not work post here again and we will try again. Good Luck DK
Brian in Ohio
02-11-2007 17:45:32
 Re: Engine parts for a 1957 Case model 509 in reply to DKase, 02-11-2007 13:56:10
Didn't mean to steer him in the wrong direction. Thanks for setting him straight.
Brian in Ohio
02-11-2007 10:12:37
Try searching for one for a 500B or a 530. A 509 is a version of a 500B, and the 530 was the later upgrade, and I think they used the same radiator.
