vac eagle hitch leaking
steven in tn.
02-11-2007 08:59:31
third party image
i have a 51 vac and am having leaks in these 2 places. one is the grease fitting and the other is around the lift lever or that block under the lever. what would be causing this? THANKS
j Heitkemper
02-12-2007 20:01:57
 Re: vac eagle hitch leaking in reply to steven in tn., 02-11-2007 08:59:31
Lucas products should be available at your local NAPA. They are NEW ,, try on line ,If not available in Your area , leave ph # ,This farm started using their products in 1995 , Not a mechanic in a bottle ,, But it will make a difference and breathe new long lasting life in every application .. Not sure where your hydro sump is located on your particular VAC, My 49 has it in the torque tube. The LUCAS stuff really works , good luck ,Jim
steven in tn
02-13-2007 16:27:18
 Re: vac eagle hitch leaking in reply to j Heitkemper , 02-12-2007 20:01:57
took the piston out today and the orings went everwhere. rotted and broke.
also the cylinder was rusted on one spot while the tractor set up for a year.
steven in tn
02-13-2007 16:26:54
J Heitkemper
02-11-2007 19:59:08
Before I tear anything like that apart ,I always try this first Put some LUCAS Hub -seal in the hydro sump, It will seal that baby up like new , Leave the tools in the box. Instead of being under the tractor You can stay on top of your tractor and enjoy the ride.. Well worth a try ,, Good -Luck , JIM
steven in tn
02-12-2007 07:01:21
 Re: vac eagle hitch leaking in reply to J Heitkemper , 02-11-2007 19:59:08
third party image
what is this called i circled ?
also there is a plug in the side, what is that for?
Sam#3
02-12-2007 15:07:00
 Re: vac eagle hitch leaking in reply to steven in tn, 02-12-2007 07:01:21
That is the Rockshaft Housing. See the discription on the next page, 135. My tractor is 50 miles away so I can't address the 'plug' in the side. (Which side?) The sump is the torgue tube between the engine and main case. See pages 52-53 of the RIE61 parts catalog.
steven in tn
02-12-2007 06:28:04
J Heitkemper,
what is LUCAS Hub -seal?
also where is the hydro sump?
Soldier Tom
02-11-2007 16:03:11
Steve, Where in Tenn? Im from over around Knoxville.
~Walk in Peace~
steven in tn
02-11-2007 18:08:42
 Re: vac eagle hitch leaking in reply to Soldier Tom, 02-11-2007 16:03:11
Soldier Tom im in lawrence co.
i took the little 5/16 line off and worked the lift. at first there was a lot of fluid but after a few lifts it slowed down.
what is in on the piston in a 51?
Joe (Wa)
02-11-2007 22:05:13
 Re: vac eagle hitch leaking in reply to steven in tn, 02-11-2007 18:08:42
The change from leather cup piston to o-ring piston occurred 1951. The problem is that the same cylinder was used for both the cup piston and the o-ring piston so there is no way to know if one has been substituted for the other w/o opening it up.
Leather cup is Case p/n V22900, cross-ref p/n A30798.
O-rings (2) is Case p/n V20353, cross-ref p/n A30757.
You can expect occassional oil seepage pass the piston even as new. The best way to check if excessive, put some weight on the draft arms and raise full up, piston will now be at the bottom of travel. With the control lever in neutral, the oil pressure on the piston is that being leveraged by the weight on the draft arms. Check at the leak-off tube fitting for excessive leak-bye like a slow drip or more. Right now you have quite a bit of oil soaked grease in the rock shaft housing so take that into account.
The rock shaft has a lip seal on the left side of the shaft but there is no shaft seal on the control valve side, that is why it leaks from the control valve block when the air, grease, & oil is trapped & pressurized under the piston by a plugged leak-off instead of bleeding back to the torque tube. The leaking grease zerk has a defective check ball, change it out.
Joe
Sam#3
02-11-2007 18:34:23
Since the rock shaft housing has oil in it and the left fitting is leaking it almost has to be the cylinder leaking. If it is just leaking by the control lever it would most likely be the control valves seals. I can't tell you if the '51 has an O ring or a cup.
Joe (Wa)
02-11-2007 10:40:04
On the front right side of the rock shaft housing there is a leak-off tubing that leads back to the torque tube housing. The purpose of the tubing is to convey oil that leaks pass the piston seal and the excess grease in the rock shaft housing to the torque tube sump.
The tube is plugged with old grease or the piston has excessive leak-bye. While the tube is disconnected, run the hitch up & down to push out the oil & grease accumulated under the piston. It should clear up in about 10 cycles with no more than a drop or two per cycle.
Joe
Paul f
02-11-2007 10:37:54
Several possibilities
Too Much grease..the rock shaft fittings do not need much grease
Plugged/restricted breather line from cylinder back to the reservoir.(called that in parts manual in reality it allows fluid that leaks past the piston to drain back to the reservoir)
Leaky piston in the cylinder (older ones may have leather cup newer ones have o- rings)
