La stuck in two gears
mike's600
02-11-2007 06:17:59
Hello, you guys ever have any problems hanging two gears. The tractor was put in reverse, backed up, problem occurs from rev to first.I owned this tractor a year or two ago, never had a problem shifting the tractor. Put on a trailer many times.
All i have is Case tractors 600's 700's 900's la's,etc. never had this problem with any of them. I think the fellow is comming out rev, missing neutral, heading to first gear, and pulling rev gear as the sector is moved causing the lock. What do you think? Thanks
Walt Davies
02-11-2007 15:00:37
 Re: La stuck in two gears in reply to mike's600, 02-11-2007 06:17:59
Pull the shifter case on top of the tranny then look for anything out of place a broken spring or such that allowed it to go into two gears at once.
Walt
Bob from Australia
02-11-2007 16:27:10
 Re: La stuck in two gears in reply to Walt Davies, 02-11-2007 15:00:37
It is easy to 'unstick' it by taking the gearbox cover off and moving the selectors.
The cause of the problem maybe worn selectors or bad gear box bearings. Had a collapsed belt pulley bearing once that caused the sticking in two gears problem in a well used LA
