Case 630 rarity
Jacob Meuth
02-09-2007 19:57:10
Hello I am looking at purchasing a Case 630 gas with a loader on it. The man is asking 3900 for it. I would say that it is about mint for its age very little rust original paint, no dents except a small ding in the fender, and newer tires. It has original wheel weights and the only thing that seems to be in need of repair are the gauges. I was wondering if this price seems reasonable, also how rare are these tractors, I never see them listed on Ironsearch or many other used tractor sites.
PhilcaseinWPa
02-12-2007 06:32:00
 Re: Case 630 rarity (w/ picture) in reply to Jacob Meuth, 02-09-2007 19:57:10
Hi Jacob, I have a 630 tractor set up the same way, wide front, triple range. I like it a lot. I have an Allied loader mounted on it with a 5' bucket. Everything said about the loader capabilities are true. Slow and weak front end. Power steering is definitely nice. When the fluid is low I can hardly steer it. Also keeping the hydralic fluid level up helps it work better. I did break a spindle on mine one time but not while I was using the loader. A machine shop repaired it and it has held up fine since. I don't use the loader much so I can live with it. If I was going to use the loader a lot I would look for another better adapted tractor perhaps with fwa. Still a good buy and a good tractor. My advice is buy it!
third party image Only the frame for the loader is on the tractor in the picture. Lift arms, bucket, and cylinder are pretty easy to put off and on.
Phil
John Saeli
02-10-2007 08:30:36
 Re: Case 630 rarity in reply to Jacob Meuth, 02-09-2007 19:57:10
Hey Jcob: How many hours on it? $3900 is a premium price. Case O Matic or Triple Range? Wide Front? The 630 isn't the best loader tractor unless it's a construction model with a heavy duty front axle and a bigger Hyd. pump. The spindles on an ag 630 wide front are really not designed for loader use. The Hyd. pump is only about 10GPM so the loader response will be slow.
Jacob Meuth
02-10-2007 13:00:36
 Re: Case 630 rarity in reply to John Saeli, 02-10-2007 08:30:36
Its a wide front with ps, triple range. The loader is only a four foot bucket I am assuming, might only be 3.5. Hour meter reads 28?? but the man selling says it was broke when he bought it. I know it came from an auto auction as the tag is still on the front headlight. Thank you for your replies.
Patrick (Mich.)
02-09-2007 21:43:40
Jacob, it sounds like a reasonable price for what you describe. Be sure it has power steering to help out with that loader! I wouldn't say that 630's are rare, but certainly less common than a 430 or 530, because the 630 was discontinued after 1964.
Don Rudolph
02-09-2007 20:22:47
That is a good price for a loader tractor in good shape. I would definitely buy it. 630's were only made for 4 years and there aren't many around. Good Luck!
