David Brown 990, 995 question
PhilcaseinWPa
02-09-2007 07:18:17
Years ago I went to a dealer to buy a used manure spreader. We got to talking and I said I was looking for a really slow tractor for transplanting. He said I got the slowest I've ever seen here. It was either a 990 or 995 David Brown. Had a 3 speed transmission with a second gear shift for a high low range and then a third gear shift that was fast / slow. In 1 low slow it was really slow. I didn't buy it but now I've seen a couple of them for sale and I was wondering how reliable these tractors were, how available are parts, and do all of them have this transmission. They are pretty cheap and I don't need another tractor but could use a slower one. Any comments? Also when Case put their name on the 990 / 995 s did they continue this transmission?
Thanks
Phil
ps Well actually we all need more tractors. Isn't that what life is all about.
Rick Z
02-09-2007 12:42:10
 Re: David Brown 990, 995 question in reply to PhilcaseinWPa, 02-09-2007 07:18:17
Good all around chore tractors.A little frustrating to work on.Can achieve some slow speeds with range gears.Differential lock on these units will get you out of most predicaments.
The 3 point hitch works well once you learn how to operate it.All the larger hp units have the a similar gearbox setup.Yes ,the ealy DB mdels (1210,1410) came in MFD.After the case aquisition in the late 70's David Brown knockoffs were sold under the CaseIH logo.(1494,1594etc)
PhilcaseinWPa
02-09-2007 07:23:42
Another question. Did the larger DBs also have this 12 speed transmission available (1200,1210, 1410 etc)? Was mfwa available?
richard in nz
02-09-2007 20:57:18
 Re: David Brown 990, 995 question in reply to PhilcaseinWPa, 02-09-2007 07:23:42
They did not all have the 12 speed box, it was an option, the standard box only has 6 speeds. The 995/996/1200/1210/1212/1410 & 1412 were all available with driven front axles but they are not common.
SteveKy
02-09-2007 17:01:21
Bought my 1210 last fall,12 speed gear box. Well pleased fired up this morning -2 no block heater just thermo start.
