exhaust manifold ferrels
INCase
02-09-2007 06:47:17
I"ve been told that you can make you own exhaust ferrels for the 800/730"s ect. from straight exhaust pipe instead of buying the high $ ones from Case. What size diameter and what length do you cut the pipe to? what is the best way to prep the manifold to accept the new ferrels? Thanks.
djm75
02-10-2007 04:26:15
 Re: exhaust manifold ferrels in reply to INCase, 02-09-2007 06:47:17
I got mine from case on my 830 they where perfectly staight no taper and no slit. but John Saeli told me you can make your own out of exhaust pipe. good luck
Jim B.
02-09-2007 21:41:18
Some OEM Case ferrules are straight, some are bigger on one end than the other. Depends on the model-application. Some are solid some are slit. Both the head and the manifold have counter bored ports to accept the 1/2" length. Be careful when/if you use a hole saw to remove the old rusted ferrule. I hole sawed mine and the counter bore ended up a little large, now the ferrule is a little loose and the gasket only lasts a few tanks of fuel. My plan to fix, when the weather gets better, is to remake the exhaust ferrules (again) but sorta flare them to fit tighter into the oversized hole sawed manifold ports. What a pain !!
other Will
02-09-2007 13:43:02
Have made them for a D. If you make them for the exhaust manifold be sure to cut a slit in them so they can expand when hot and contract when cooled. Clean up the grouve in the block and manifold with a hole saw (carefully).
John Saeli
02-09-2007 16:52:15
 Re: exhaust manifold ferrels in reply to other Will, 02-09-2007 13:43:02
I've seen them whole & slit. Mine end up being slit anyways when I make them out of a larger diameter pipe & have to trim them back.
Paul f
02-09-2007 07:45:08
For a DC
A26433 Ferrule Intake $6.39 1-1/2" OD 1-3/8 ID 1/2 Long
A27908 Ferrule Exhaust $9.34 1-3/4 OD 1-5/8 ID 1/2 Long you might order one of each from Case then make the rest you need
