david brown 990
cam2
02-08-2007 14:47:45
i can only engage the pto with the tractor shut off other wise it just grinds in gear at an idle,until i slam it in,seems to be no neutral just on or off.help
Ed Sutton
02-12-2007 14:48:00
 Re: david brown 990 in reply to cam2, 02-08-2007 14:47:45
There should be an inspection plate on the bottom of the transmission/clutch area, beneath the clutch. You might check there with a good light and see if there appears to be too much travel in the linkage, in the second stage. You might be able to get away with adjusting the linkage, and that will be a lot less expensive. If the PTO is turning when the clutch is fully depressed under a load, you probably will have to do clutch work, an annoying and time-consuming task, to say the least, as the tractor has to be worked on from the top with removing the top housings, etc. Hope this helps.
Ed
Roosterva
02-08-2007 16:12:59
Either the clutch is way out of adjustment. Highly unlikely as it would have gotten gradually worse before it completely quit working. Most likely the PTO clutch is worn out or damaged and will have to be replaced. Not too bad of a job.
