CaseOmatic Torque converter
INCase
02-07-2007 16:59:05
When a torque converter "goes bad" what usually goes wrong? Is there another clutch inside the torque converter that disconects when the clutch is depressed? Thanks.
Dedrick
02-08-2007 09:19:20
 Re: CaseOmatic Torque converter in reply to INCase, 02-07-2007 16:59:05
Torque converter operate at 40 lbs psi. just enough to keep air out , the main clutch is located behind the converter operate at 125 or so Psi. and there an other clutch called direct drive , it located in front of converter also work at 125 psi. Usally the relief valve near the pump has dirt in it or stuck open. if worn out the main clutch has pressure 125 psi and when the direct lever is engaged the pressure will drop off.
INCase
02-09-2007 06:44:15
 Re: CaseOmatic Torque converter in reply to Dedrick, 02-08-2007 09:19:20
Thanks. Is the relief valve accessable from the outside or do you have to take the pump off (right side of tractor)? I"d been trying to study the diagrams but its not real clear. The direct drive seems to be ok. the regular clutch sometimes slips and sometimes works (quick firm engagements.
Dedrick
02-09-2007 13:12:57
 Re: CaseOmatic Torque converter in reply to INCase, 02-09-2007 06:44:15
Yes you have an 800 or 739 -830 Right side and take housing off and pump is behind it there and you find relief valve on the pump. John
