fuel problems
Scott Hawley
02-07-2007 16:14:34
Hope someone can shed some light on my problem. I have a case 580ck tractor and started having trouble getting her to run the other day. Of cource it was 10 below and that did'nt help. It would turn over but it seemed froze up so in went the dry gas. I waited until the nest day and nothing, same thing. then I noticed that my gas has disapeared and had ended up in my oil ( up draft carb) so I figured the float has stuck so I took it off and had it rebuilt( it needed it bad). Alls going good until I put it back on. Still won't start. Checked the plugs have new electronic ignition so sparks there. Then I checked the sediment bowl. It was clean but I took it off and drained it anyway. Then I noticed something, if I tuned on the gas without the bowl in place, gas came out just fine. When I put the bowl back on and tightend it up the gas would not fill the bowl at all..... . shut off. If I backed off on the nut underneath gas would start to flow but of cource it would then leak. I have torn off the gas line and the bowl and valve assembley and nothing is plugged but the carb is not getting gas. It did run for a few minutes and then ran out of gas in the line..... ..... .I can't figure this one, air locked maybe?.....I could use any help.
Thanks in advance,
Scott Hawley
Scott Hawley
02-08-2007 09:00:06
 Re: fuel problems in reply to Scott Hawley, 02-07-2007 16:14:34
Thanks for all the help boy's. I did what you said Roger and mj. It had a huge amount of air it seems to be bled out, must have opened that fuel line at the carb three times till it started to flow good. Let the gas cap off too. Finally it had enough gas to run and keep going. Of cource the oil in the tranny was cold, it was a warm 5 degrees here today so it took it's time getting going but, it runs like a bear now and all's right with the world again.
Thanks again
Scott
Roger300
02-07-2007 16:25:09
Scott; Your test with the fuel bowl, it was acting as it should. Fuel can't enter the sediment bowl when it is good and tight, there's no place for the air to go to let fuel in. If you would then loosen the fuel line at the carbureator it could then fill up, tighten the fuel line back up and then try starting the tractor. This should help with your concern with the part of the puzzle. Roger
mj
02-07-2007 16:23:27
Is your cap vented? Loosen the cap and try it.
