Engine Compatability
Rustidiot
02-06-2007 20:25:45
Thanks in advance for your help. I have a Case 400 LP Hi-Clear with a bad engine. I also have a Case 400 diesel row crop with a good engine. Will the diesel fit the Hi-Clear without major modifications, especially in the flywheel and clutch area?
Just a thought
02-08-2007 19:53:45
 Re: Engine Compatability in reply to Rustidiot, 02-06-2007 20:25:45
If your diesel runs, why scrap it to make the High Crop run? You would loose money there that you already have. Better off selling it to finance a proper restoration of the LP engine.
Rustidiot
02-08-2007 21:34:23
 Re: Engine Compatability in reply to Just a thought, 02-08-2007 19:53:45
O.K. guys. You win. I'll rebuild the LP engine and hope I can get the regulator rejuvenated. It's an Ensign and I don't know where to get a kit for it.
A question: Can someone tell me if the propane tank is supposed to be red or Desert Sunset? The one I bought from Ruscha had been painted green. The mag had been replaced with a distributor, but it runs O.K. with it.
Rick Z
02-08-2007 08:37:59
On most propane fired units valves are the first things to go.I would try a wet compression test to determine what shape the engine really is.If the test shows that it is valves it will be a reasonably cheap fix.On a tractor of this vintage I would try to stay original as someday it will be worth a good chunk of change.
Rustidiot
02-07-2007 21:28:41
The propane system was removed from the Hi-Clear and a gasoline tank was installed. I don't know how long it was run on gasoline, but the engine is slobbering oil out through the exhaust. I found the right LP tank (1955) and a regulator & carb off a 400 LP that has been sitting for years. Don't know if the regulator is good. A rebuild will cost money that I don't have, however, I have the diesel engine. I know that I should be shot if I put the diesel engine in this tractor. Only 58 built and I don't know how many were LP out of the 58.
Jeff From WI.
02-07-2007 15:17:09
Rebuild the LP :) you will be so happy!!!!! ! Jeff
mj
02-07-2007 10:02:35
What Don L. said!
C. Amick
02-07-2007 09:15:22
What's wrong with the LP engine?
Don Livingston
02-07-2007 04:36:34
Easy change over. no majors at all. But can you justify taking a very very rare tractor and putting the wrong engine in it. The serial tag will tell on you. Don't do it.
Don L.
